hii,
ihave
intel core2duo e8400 e0 with cm hyper 212 plus
gigabyte ep45-ud3r rev 1.1
2*2gb kingston hyperx pc 8500 -- cl7 bus (1066)
ati hd 5850
psu:cooler master 600 watt
i have succefully overclocked my system yesterday but i face aproblem . first i overclocked to 4.05 ghz (450*9) with 1.293 volt and 900 mhz ram frequency with 2.00d spd ram profile& 1.9 volt. the system was stable for 8 hours using prime 95. the problem appeared after that when i shut computer down then open it during first boot when i turned on pc the power led turned on then turned off for 2 seconds then the computer boots. but ifound somthing to solve it but it,s not stable i enterd bios and changed spd ram profile to 2.00b .computer refused to boot however it gives me also 900 mhz.ichanged it again to 2.40b it gave me 1068 mhz ram frequency i changed ram voltage to 2 volt and restart the computer boots normally without power led turnig on then off . but the system didn,t complete 2 minutes in prime 95 test . so i can,t found solve for my issue ... plz help
some cpu-z pics
ihave
ati hd 5850
some cpu-z pics
