AMD 965 overclocking over 4.0 PLEASE Help.
Hello could some one help me get a higher overclock ive reached " The wall " my temps are running in the low 30`s low 40 peek and i cant get any more out of it. Im new to overclocking and from what i have been told as long as your temps are low you have room for higher clocks but i cant get there. Im running Amd 965 BE with a crosshair III formula and 8 gigs of mushkin blackline ddr3 1600 T1 fan cooled ram in windows 7 x64 (GFX 5850 BE i disabled eyefinity during all overclocking) and im on liquid cooling ( EK supreme high flow cpu and motherboard water blocks) in a Thermaltake Kandolf LCS case
fsb : 200
cpu x20 1.5v temp 31
ram 8 Gigs @ 1600 @ 1.95 T1 OCZ 4000 rpm fan cooler
NB 2400 @ 1.3v temp 34
SB 1.2v temp 32
HT 2400 @ 1.3v
Any ideas id like to get to 4.2 or higher
9 answers Last reply Best Answer
More about overclocking help
  1. Whoever told you that was wrong. every chip is different, and they all have a physical limit. If adding voltage no longer stabilizes you, that means you have hit the limit of your chip.
    sorry, but that's as far as you can go. (nothing to scoff at though, its a very nice overclock)
  2. Thank you... Thats kinda what i figured... but i was hoping it was my lack of experience and knowledge holding me back not the chip. I guess i didn't get a" golden chip" LOL
  3. Thats why those liquid nitrogen guys still can't overclock to infinity despite their chips being -200C. They can only add so much voltage and get higher overclocks until the chips break. Those guys are crazy and has nothing to lose.
  4. Fair enough... i guess ill be happy with what my O.C and stop now before i break something lol
  5. Best answer
    Your CPU-Z validation info:
    Windows 7 Enterprise Edition (Build 7600)
    CPU Arch : 1 CPU - 4 Cores - 4 Threads
    CPU PSN : AMD Phenom II X4 965 Processor
    CPU EXT : MMX(+), 3DNow!(+), SSE (1, 2, 3, 4A), x86-64, AMD-V
    CPUID : F.4.3 / Extended : 10.4
    CPU Cache : L1 : 4 x 64 / 4 x 64 KB - L2 : 4 x 512 KB
    CPU Cache : L3 : 6144 KB
    Core : Deneb (45 nm) / Stepping : RB-C3
    Freq : 4013.59 MHz (200.68 * 20)
    MB Brand : Asus
    MB Model : Crosshair III Formula
    NB : AMD 790FX rev 00
    SB : AMD SB700 rev 00
    GPU1 Type : Radeon HD 5850
    GPU1 Clocks : Core 930 MHz / RAM 1300 MHz
    GPU2 Type : ATI Radeon HD 5800 Series
    GPU3 Type : ATI Radeon HD 5800 Series
    DirectX Version : 11.0
    RAM : 8184 MB DDR3 Dual Channel
    RAM Speed : 802.7 MHz (1:4) @ 7-7-7-20
    My first post was indicating you take a look at the black edition overclock guide, even though you may very well be at your CPUs limitations I do see some things that could be affecting you getting any higher than you are and they're covered in the guide.
    I do have a question for you as to what exactly is your GPU configuration in relation to what CPU-Z is showing?
    Dropping from 8G of memory 4 x 2g, to 4G of memory 2 x 2G in the primary ASUS dual channel slots, may very well get you a higher clock, that's covered in the guide.
    Overclockers Club only ran 4G of memory when they tested the M/B, but they were using a 955 cpu to OC with.
  6. ive been doing all my overclocking with the gfx at stock speed 765 - 1125.
    ill try dropping back to 4 gigs of ram i re read the guide i must have missed that note initially. sorry
    mini dump files read (processor cache failure )
    A fatal hardware error has occurred. Parameter 1 identifies the type of error
    source that reported the error. Parameter 2 holds the address of the
    WHEA_ERROR_RECORD structure that describes the error conditon.
    Arg1: 0000000000000000, Machine Check Exception
    Arg2: fffffa80092688f8, Address of the WHEA_ERROR_RECORD structure.
    Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
    Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
    Debugging Details:
    BUGCHECK_STR: 0x124_AuthenticAMD
    PROCESS_NAME: System
    fffff880`031af6f0 fffff800`02d09a89 : fffffa80`092688d0 fffffa80`06bbcb60 fffffa80`61656857 00000000`00000609 : nt!WheapCreateLiveTriageDump+0x6c
    fffff880`031afc10 fffff800`02beb667 : fffffa80`092688d0 fffff800`02c645f8 fffffa80`06bbcb60 00000002`00000005 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
    fffff880`031afc40 fffff800`02b53c45 : fffff800`02cc6360 fffffa80`092fbbe8 fffffa80`092fbbe0 fffffa80`06bbcb60 : nt!WheapProcessWorkQueueItem+0x57
    fffff880`031afc80 fffff800`02acc961 : fffff880`0115de00 fffff800`02b53c20 fffffa80`06bbcb60 00000000`00000000 : nt!WheapWorkQueueWorkerRoutine+0x25
    fffff880`031afcb0 fffff800`02d63c06 : 00000000`00000000 fffffa80`06bbcb60 00000000`00000080 fffffa80`06ba8b30 : nt!ExpWorkerThread+0x111
    fffff880`031afd40 fffff800`02a9dc26 : fffff880`02f64180 fffffa80`06bbcb60 fffff880`02f6efc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
    fffff880`031afd80 00000000`00000000 : fffff880`031b0000 fffff880`031aa000 fffff880`03df6540 00000000`00000000 : nt!KxStartSystemThread+0x16
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: hardware
    IMAGE_NAME: hardware
    Followup: MachineOwner
    im getting this with prime 95 as i increase either multiplier or voltage, even if im successful with 32M hyperpi this makes me curious weather ive hit my cpu`s max potential or if i have something out of wack some where else in my O.C
    ill try the 4 gigs of ram and post the results thank you for your help
  7. One thing your Crosshair III Formula has is the Mem OK button on the M/B which is a sweet feature for syncing multiple memory modules that ASUS has added, but if you'll look in your M/B manual around 2.4.2 Memory Configurations it states, "It is recommended to install the memory modules from the orange slots for better overclocking capability", since that's in the manual but you have no orange slots, they probably kept that from the Crosshair II Formula manual and are referencing and indicating the blue primary slots.
    At least that is what the downloadable online manual for your M/B states.
    Also you might try dropping your NB and HT back to 2000mhz.
    I suggest recording all your settings for your stable 4G OC, then try using the guide and see what that gets you, if it doesn't pan out for you, you can setup the BIOS settings to your 4G settings and be back where you are now.
  8. Best answer selected by grahamie.
AMD Overclocking
