Tom's Hardware > Forum > CPU & Components > Other Components > 4pin molex fans? which fan to buy?
Forum CPU & Components : Other Components - 4pin molex fans? which fan to buy?
Hello together, I've found a really good special offer, and wanted to ask if I should buy it. Usually I would inform myself but this offers seems not to last for a too long time and I have to do other stuff atm.
The product im talking about is a fan called Nanoxia Highflow FX+12 - 2000 PWM or the 1250 PWM version of the same fan.(http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_49&products_id=24880)
They both "use" a 4 pin molex connector and my first question is If many Am3/am2+ motherboard which aren't to expensive (f.e Gigabyte GA-MA790X-UD4) would support having two aditional 4 pin fans (+the fan from the Xigmatec S1283 + 2 fans from Antec 300).
I count 5 fans in total but the descriptions of the motherboard say's 4x Fan (I don't know if 3or 4 pin).
Is the fan of the Cpu included when saying 4x Fan or does it mean you cann install 4 additional fans (which I want)
my second question: which version should I buy one with 380–1.250 turns per minute or 600–2.000 I want to overclock and need good cooling but I don't know how many turns/minute make sense.
Does it make sence buying such fans or should I just buy simple 3 pin fans?
Thank you Erdinger
Sponsored Links
no answers? are my questions unclear or what?
could you at least tell me if a motherboard with 4xfan supports 5 fans in total (including cpu fan) and if all motherboard have 4 pin conntectors?
Reply to Erdinger
Ok i've looked at the pc i have right now and reckognized that only the cpu fan has 4 pins (no idea why) and that even with 3 pins I could adjust the speed of the other fan... (Bios it's more silent now ^^)
Can someone please explain the difference between 3 and 4 pin and which I should buy as chassis fans and why?
Kind regards Erdinger
Reply to Erdinger
- 0 +
Hi,
Go here and download the manual for the GA-MA790X-UD4P MoBo, see page 7 for Mobo layout:
http://www.gigabyte.us/Support/Mot [...] leID=19145
The CPU fan connects to the motherboard...there are 3 Case fan connections on your MoBo, Power fan, Systems_fan 1 & System fan_2...these are used to control & monitor the fans speed. As far as I know you can put 2 or more fans together on 1 Molex connecting cable to your PSU. Hope this helps my tech knowlege is limited.
Message edited by Jim937 on 06-10-2009 at 10:01:26 PM
Reply to Jim937
thanks a lot that helps
Reply to Erdinger
There are 601 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
