Tom's Hardware > Forum > CPU & Components > CPUs > Heatsink installation problem, did I get the wrong heatsink? Need help
Forum CPU & Components : CPUs - Heatsink installation problem, did I get the wrong heatsink? Need help
Hi,
It is my first to build a computer myself.
I bought a AM3 mobo and Phenom II 720.
I am trying to install this heatsink:
Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler W/TX-2
http://www.newegg.com/Product/Prod [...] 6835207004
I was told that heatsinks for AM2 will work on AM3 boards, but when I followed the manual, I had this problem. The two mounting clips of the heatsink are not long enough to reach the retention brackets on the board.
Here is the pictures:
http://pa.images22.51img1.com/6000/yeungyue/ad4b50de1f5500e1828cdc7218e22dff.jpg
Please look at the circled area.
I think if I use force to push both mounting clips really hard, I can still make them reach the retention brackets, but I'm afraid that might hurt the CPU and the plastic retention brackets on the board will break.
Please give me some help, thank you!
Message edited by beef1218 on 06-09-2009 at 10:57:25 PM
Sponsored Links
Put the motherboard a flat hard surface and push it down very hard with a flat head screw driver in the slot provided on the clip. Yes, a large amount of force is required.
------------------------------ GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
http://farm3.static.flickr.com/2520/3850950213_aea6bbbcfe_o.jpg
Reply to wuzy
Thank you, wuzy.
I installed it successfully.
Reply to beef1218
There are 706 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
