Tom's Hardware > Forum > CPU & Components > CPUs > Applying Thermal Paste On AMD Athlon XP(T) Help?
Forum CPU & Components : CPUs - Applying Thermal Paste On AMD Athlon XP(T) Help?
So i wanted to reapply the thermal paste on a 5 year old computer that was given to me and after struggling to get the heat sink off, and when i finally did i have never seen a processor like this before and have no clue how to apply thermal paste.
I took a picture and attached it below so you can see the processor. I think its just the small rectangle n the middle but i don't know.
http://i39.tinypic.com/8zimtv.jpg
Sponsored Links
Apply a thin layer of thermal paste on the middle part that's already covered with old thermal paste. First clean it up using rubbing alcohol and a lint free cloth. Then apply new thermal paste.
Reply to GhislainG
Thanks you so much. Once i took that heat sink off and saw that old CPU i had no clue what to do. I couldn't tell i that was thermal paste or not.
Reply to dizzizane
There are 555 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
