Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound Card Advise?
Sound Card Advise?
Forum CPU & Components : Sound Cards - Sound Card Advise?
I'm wanting a good S.C. for under 175.00... and this is what i have to have...
PCI-e, (if not, pci is fine, but prefer PCI-e)
No CPU bottlenecking... So my pc will Perform at peak performance.
I'm desideing on Creative Sound Blaster X-Fi Titanium Fatal1ty Professional 70SB088600002 7.1 Channels 24-bit 96KHz PCI Express
http://www.newegg.com/Product/Prod [...] 6829102019
but people are saying to go with another brand... What should i do???
Main / Big consern.... No CPU Bottlenecking...
hope some one can help me ... thanks
Sponsored Links
First off, I can't stand Creative based products due to their poor driver/product quality. Also, PCI-E/PCI isn't an issue, especially since sound cards don't need nearly enough bandwith to max the PCI bus.
I'd recommend either the ASUS Xonar line or a Azuntech product.
For the Xonars, the two cards to look at would be the D2(X) and the STX Essence (The D2 is PCI, the D2X is PCI-E via a bridge chip). For Azuntech, look at the Prelude and Forte.
Essentially, the Azuntech line is basically Creatives core design with some changes and good driver support, meaning you get "true" X-fi support. That being said, the ASUS Xonar line gets a major edge for HT systems compared to other cards, and recent driver releases emulates X-fi through software. (Note: If you own Vista, thats exactly what Alchemy does, meaining X-fi support is done through software regardless).
http://www.guru3d.com/article/asus-xonar-d2x-review/ (Xonar D2X)
http://www.guru3d.com/article/asus [...] tx-review/ (Xonar Essence STX)
http://www.guru3d.com/article/auze [...] view-test/ (Forte)
http://www.guru3d.com/article/auze [...] 71-review/ (Prelude)
Theres a few truly high quality cards (Such as the ASUS HDAV1.3) that I'm not listing, as they are more for HT systems then for gaming, which is what I'm assuming your looking for.
------------------------------ http://valid.canardpc.com/cache/banner/622598.png
Reply to gamerk316
Asus Xonar essense!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! end of conversation
Reply to AdamDBurns
asus xonar this thread is done
Reply to jdigital1983
To be fair, the Essence STX isn't the best choice for analog connections. Heck, for analog connections, I'd just reccommend the "Daughter Card" (The analog output card for the ASUS HDAV1.3) over the Essence STX. For digital sound systems though, you can't beat the Essence STX in my mind, although the Prelude may give it a run for its money...
Reply to gamerk316
Does the Asus, have a Good cpu and ram on it, so there wont be any CPU bottlenecking...???
Thanks again everyone... I'v been reading about that asus xonar... ill look in to that... and make my switch..
thanks... hope to hear back from ya.
Message edited by renegeek on 06-10-2009 at 10:31:05 PM
Reply to renegeek
OK, i think i made up my mind...
Looks like i'm going with Auzentech X-fi Forte 7.1 Soundcard...
Because...
1.) i'v been a Creative owner all my life, since 1989, never had any problems.
2.) Asus has game , bug problems... and other things.... I checked out newegg for these issues.
3.) Auz. has a 64 X-ram, to reduce CPU bottlenecking.
4.) just seems like i'll have better luck... with my current Sony THX 500watt / 5.1 Sound system
Thanks all, for your help...
Reply to renegeek
You did not say what you were using the sound card for. If you play a lot of games then stick with the fatality card but if not then go for the Asus.
Reply to ragsters
I mostly game, and listen to some music, and watch movies. and do a little music recording...
sorry, i thought i had stated what i was doing, when i was say NO cpu bottlenecking... my bad... sorry.
Reply to renegeek
No soundcard will ever bottleneck the CPU; XRAM was the best marketing tool Creative ever came up with. Heck, a Realtek onboard chipset, which is CPU only, doesn't bottleneck the CPU (unless you have a weak P4...).
I also find it odd that you noting the newegg reviews, especially since both the Xonars I listed have higher ratings then anything Creative has on newegg...
It would help if we knew WHAT you needed the card for, as a few features are not on any Creative model (Dolby Digital Live is only avaliable on the STX Essence, unless you want to PAY Creative/Azuntech, etc), and most people would agree the Xonar line is far better for a HTPC then Creative/Azuntech.
Generally, Gaming = Azentech, HTMP = ASUS. Never buy directly from Creative though; too many legacy problems, and buggy drivers.
Reply to gamerk316
I totaly agree with ya, i read the reviews, and doc's, and stuff... and the asus is a better choice... but im looking for something for , mainly gameing, and to reduce some cpu bottlenecking... (there were some game issues with the asus board) so i going to go with the azen.
but if, later on i dont like it, then ill buy the asus... live and learn... :) right.
but thank you all for your expertise... :)
Reply to renegeek
Yeah, I probably came of a bit harsh before, but I was serious about my points. And yes, Creative does suck. :D
Reply to gamerk316
You confuse facts... X-Fi processes audio in hardware - with or without the XRAM (which only helps in selected EAX 5.0 games). But X-Fi processes audio in hardware in all games and in fact in all appplications and there is performance difference to e.g.: onboard audio
http://www.theinquirer.net/inquire [...] vestigated
X-Fi Titanium cards come with DDL at no extra charge (stop spreading FUD, Gamerk, for kristssake...)
@renegeek: Xonars are good and X-Fi are good - if it is performance and accurate gaming audio you are after - get the X-Fi.
Reply to uncle_ben
Thanks... I beleve ill be going with Azun card... but i'm going to spend a few more days, to find out the specs of each... and make a final say... i wont be buying this card, for about another month... so i have lots of time...
this is all for my comming soon Gameing pc...
BIOSTAR TFORCE TA790GX 128M AM3/AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard
x2 = EVGA 512-P3-N963-TR GeForce 9600 GSO 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX
x2 = G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1100 (PC2 8800) Dual Channel Kit Desktop Memory Model F2-8800CL5D-4GBPI
Acer X233Hbid Black 23" 5ms HDMI Full 1080P Widescreen LCD
KINGWIN KW-01 Gray 8 Buttons 1 x Wheel USB 2.4G RF Wireless Laser Mouse
AuzenTech AZT-FORTE X-Fi Forte 7.1 Low Profile PCI Express Sound Card
Scythe SCMNJ-1000 80mm Sleeve "NINJA MINI" CPU Cooler
x10 = Link Depot FAN-4LED-80BU 80mm Blue LED Case Fan
Price = about 1,000.00 bucks or so... but still working on my items...
i all ready have speakers, and case and PW X-Finity ultra 600watt , 250gig HD, Sony dual-layer DVD-RWx20... and etc...
thanks for your help... :)
Reply to renegeek
- 0 +
I literally just got a Xonar D2X (as in put it in my computer a couple hours ago), and so far, I'm impressed. I had an X-Fi originally about a year ago, but the drivers were so buggy I couldn't use it without getting BSODs every time I'd try to do anything (slightly exaggerated). I'd get the Xonar, and check out zipzoomfly.com because they have a great price on the Xonar right now.
Reply to chedrz
+1 for everyone who recommended the ASUS Xonar, and +1 for those wont buy Creative products anymore.
Reply to starams5
Thanks guys... ill look into that on zip... see what the price is...
thanks
Reply to renegeek
There are 1057 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 ifko_pifko won the Freshman badge
  • 01:00 Riser won the Spy badge
  • 01:00 spud won the Spy badge
  • 13:27 evongugg won the Sophmore badge
  • 01:00 gtvr won the Freshman badge
  • 01:00 Tech30 won the Freshman badge
  • 01:00 batuchka won the Freshman badge
  • 01:00 copfrance won the Freshman badge
  • 11:24 2shea won the Sophmore badge
  • 01:00 alexreynolds won the Freshman badge
