For a year now I have been always browsing Tomshardware and just now decided to make a forum account.
I am looking to build a new computer soon and I would really appreciate it if you could just check over my list and make sure I am not buying something that is not compatible with another part and parts that are Overpriced. (Note: All prices are in Canadian so prices are going to be substantially more compared to US).
My budget is $3000 plus or minus a few hundred bucks
*Note I am only 14, so I ain't a genius with a computer and don't have alot of building experience.
The build is mainly for watching HD movies and playing games maybe some video rendering and little animation. I want this computer to last for around 4-5 years. (2-3 years for gaming)
LIST:
OS: Microsoft Windows Vista Home Premium Edition 64BIT DVD OEM $148.99
http://www.ncix.com/products/index.php?sku=22438
Case: Antec Twelve Hundred Black Steel ATX Full Tower Computer Case $193.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811129043
PSU: Corsair HX1000W CMPSU-1000HX 1000W ATX 20/24PIN ATX 80A 12V Afc Modular Power Supply W/ 140MM Fan $275.99
http://www.ncix.com/products/index.php?sku=28797
HD: Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM SATA 3.0Gb/s ( Will be getting another one when I get more money) $224.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136296
I don't Need Space
MOBO: EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard $374.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813188039
CPU: Intel Core i7 920 Nehalem 2.66GHz LGA 1366 $359.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115202
Cpu Cooling:
Arctic Cooling MX-2 Thermal Compound Paste $9.99
http://www.ncix.com/products/index.php?sku=26895
Coolermaster V8 CPU Heatsink Cooler (Says lga775 but has a lga 1366 bracket) $71.99
http://www.ncix.com/products/?sku=35004&vpn=RR-UV8-XBU1-GP&manufacture=COOLERMASTER
RAM: CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) $249.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145224
GPU: BFG GeForce GTX 295 576MHZ 1792MB 1.998GHZ GDDR3 PCI-E (Will get another one of these before Summer) $624.99
http://www.ncix.com/products/index.php?sku=35672 (It says 659.99 but price compared to Newegg.ca they will deduct the difference)
Monitor: ASUS VH242H Black 23.6" 5ms HDMI Full 1080P Widescreen (Buying this but will start using my 42" TV) $270.49
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236052
Headset: PLANTRONICS GameCom 367 3.5mm Circumaural Stereo Headset $49.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16826265064
Mouse: Logitech G9 laser Mouse $59.99
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10094050&catid=27320
Keyboard: Logitech G15 2ND Gen Gaming Keyboard $69.98
http://www.ncix.com/products/index.php?sku=26151&promoid=1065
TOTAL: $3399.28 CDN or $2,629.36 USD With shipping + tax (Weak Canadian Dollar)
I need some help cutting my total to atleast $2800-$3200 CDN
Something I really need to know is my Power Supply good enough to eventually support Two gtx 295's? 2 HD's maybe even 4 or so later?
THANKS IN ADVANCE
LIST:
I don't Need Space
Cpu Cooling:
THANKS IN ADVANCE
