This is the system I will probably build. T'M GOING TO BUY ANOTHER 1GB 4780 in the near future so the power supply needs to consider that!
I'm thinking modular...?
Thanks in advanced for any help.
Processor
Intel Core 2 Duo E8500 3.16Ghz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Processors+-+Desktops-_-Intel-_-19115036
Processor Fan
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Bracket
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
Mother Board
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358
Graphics Card
Radeon HD 4870
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
Memory
G.SKILL HK 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBHK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231219
Drive
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Raid Controller
HighPoint RocketRAID2640X4 PCI-Express x4 SATA / SAS Controller Card RAID 0/1/5/10 JBOD
http://www.newegg.com/Product/Product.aspx?Item=N82E16816115050
Disk Drive
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16827136152
Processor
Processor Fan
Bracket
Mother Board
Graphics Card
Radeon HD 4870
Memory
Drive
Raid Controller
Disk Drive
