Tom's Hardware > Forum > Graphic & Displays > ATI > Ati x800 installation problems
Forum Graphic & Displays : ATI - Ati x800 installation problems
when i try to install my ati radeon x800 agp 8x video card my computer keeps telling me the card has no power. i have a 550w power supply and i have the molex cable plugged into the card. i even tried using an external power just to run the card and i keep getting the same message that the card has no power. PLEASE HELP ME!!!
Sponsored Links
Probably just a bad driver install. Uninstall your drivers and run drive cleaner pro, of you could reformat in the extreme case ^_^. Then install a supported driver. I believe that AMD removed support for the X800 cards on newer drivers. While your messing with it go into the BIOS and turn off fast read and fast write.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
thats exaxctly why its telling you that......look on your video card, in the back of the video card you will see a 4pin molex plug, just like the one you see on a CD-ROM or Hard Drive. You need to plug in a plug from your power supply to your video card and press it in to make sure that its all the way in....
Message edited by ricman on 04-03-2009 at 08:08:45 PM
Reply to ricman
There are 511 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
