Help me out and give some suggestion.
compidiot
15
Hi, i building a i7 computer but i need some feed back before i invest on the computer. I want the computer to be able to last long and its for gaming purposes.
so this is my build :
Processor : Intel Core i7 920 2.66ghz
Motherboard: Gigabyte GA-EX58-Extreme X58 chipset
Graphic Card : Sapphire Redeon HD 4870 1GB PCIX Crossfire
Ram: Kingston DDR3 PC 1066 (2GB x3) = 6GB
Hard Disk : Seagate SATA2 7200rpm 500GM 32MB
Power Supply : Cooler Master Real 750w
CD/DVD : LG 22x DVDRW SATA
Casing: Not decided yet.
This is my i7 build, i need opinions from Pros out there.So feel free to correct my build. :) thank you.
battlemarz
184
I would change the hard drive to a WD Caviar Black 640gb. Seagates have had some problems lately.
Also I would go with a Corsair 650TX for a single 4870. Great deal on that PSU right now. If you are looking to add a second 4870 later go for the 750 or 850.
If you do plan to add a second GPU later, look into the Asus P6T V2 as it is set up very well for dual card solutions.
theAnimal
2,370
i7 does not offer good bang for the buck for gaming. A C2D or C2Q would offer the same performance for less.
More info would help; click the link in my sig.
Good suggestions from battlemarz.
theAnimal is correct, but with the i7 build you have a better chance to upgrade the CPU later if you feel like it. If you take his advice I'd suggest Q9550 + GA-EP45-UD3P + G.Skill PI Black DDR2-800 2x2GB.
Case: RC-690, NZXT Tempest, CoolerMaster Haf 932, Antec 902 - it depends on budget and your personal taste.
compidiot
15
thanks for all the suggestions guys.
But i m think i m going to stick to i7 :\ its sounds cooler ^^
i need more suggestion on mobo actually.
i have been struggling between Asus P6T deluxe, Asus P6T deluxe V2 , GA-EX58-Extreme and GA-EX58-UD5.
some info so that u guys can give me a better mobo suggestion:
i may OC the i7
most probably only using 1 GPU (Sapphire Radeon HD 4870 1gb)
i want to use it for a long time :\
Pls give me ur priceless advise and suggestion. I will be happy if u write the whole build out :X
Are you in the USA, Canada, UK? We need to know so we can pick a retailer that ships to you.
If you're getting an ATI card and don't plan a very high overclock, then a cheaper MB like GA-EX58-UD3R would do nicely. The others cost more, and a large part of the difference is because they pay nVidia licensing fees to support SLI (i.e. two or three nVidia cards).
compidiot
15
hmm i m from other countries ):
after discussing with my parent, i only have around USD$900 so i have to change my build :\
to :
Antec 900 casing
Intel C2D E8400 3.0ghz( Probably OC-ing to 3.5ghz)
Gigabyte-EP45-UD3P
Kingston KHX6400D2LLK2/4GB
LG 22x DVDRW sata
Saphire radeon HD 4870 1GB
Western Digital 500GB 7200rpm
Corsair 520HX 520w
CoolerMaster Hyper TX2
Pros please help me ): is my power supply enough? is the cooler good? i need a gaming system so should i go quad? please give me some advice. sorry for wasting you guys time :\
battlemarz
184
Don't worry about wasting our time, we understand money can be tight.
Change up your hard drive to a WD Caviar Black 640GB if you can find them where you live. Larger, faster, and probably cheaper per gigabyte.
I don't know how good that CPU cooler is, but for core 2s I pretty much always recommend a Xigmatek.
Your power supply should be enough for one 4870. If you are apprehensive about it go for a Corsair 650tx. If you are going to possibly add another 4870 later, then definitely get at least the 650tx if not the 750tx.
The 650TX has enough power for two HD 4870 cards, but you'd need to buy molex to PCI-E adapters when you buy the second HD 4870. That's because the 650TX has 2 PCI-E connectors and each HD 4870 needs two connectors. The 750TX has 4 connectors so it wouldn't need those adapters.
