I need to buy a new power supply to be able to handle a new video card and ram. Can I buy just any type? Are there certain types for certain computers?
I am using a HP a1600n (yes, I know it's crap...it's only for WoW), I am getting 4 gigs of ram and a 9800 gtx card. I planned on getting a 750 or 800 watt power supply.
Probably not a great idea considering there is probably a 300W PSU in that HP and at best can run the stock configuration. I have an HP that has a similar style case and it is using a standard ATX PSU. You can always open it up and check for yourself, but I'm pretty sure it will be standard. Therefore since you are only using one card I would suggest something like...
And dont get the 9800GTX+, instead get the GTS 250...both the 9800GTX+ and GTS 250 have the same chip but the GTS250 has a smaller PCB and better circuitry and consumes less power...
I was thinking the same thing when ragsters suggested the PC Power. The thing is the Antec you suggested is the same price and the PC Power is a better PSU, he would just have to deal with the rebate.
I would suggest a 4850 instead of either the 9800GTX+ or the GTS 250. It performs the same and can be found for about $30 less.
Here is one that's $79.99 after promo code and rebate. Code ends today.
Message edited by ausch30 on 06-11-2009 at 04:56:14 PM
