Hi! I was tossing together a new Core i7 PC and had a couple of questions.
First, I was planning to re-use my old computer's 700W OCZ Game-XStream power supply. Will it be strong enough to drive a Core i7, two 8800GT's in SLI, and about four 7200 rpm hard drives - or should I think about replacing it with something like an 850W?
Second, the motherboard I am looking at has three PCI-Express slots for SLI (Asus P6T). With dual slot 8800GT's, I am going to end up with one PCI slot and one unused SLI supporting PCI-Express slot left. My question was, will those PCI-Express cards with the tiny little connector work in a full sized PCI-Express 2.0 slot that is meant for a video card, or do I basically just have one normal PCI slot to work with and an empty card slot that would only be used if I tossed in another video card? More directly, I was wondering if I could stick a PCI-Express sound card in that unused third SLI slot without problems.
Third question... Has anyone compared the Razer Barracuda AC-1 and the Sound Blaster X-Fi Xtreme Gamer? I have enough in my budget to pickup a new Sound Blaster for the latest EAX support and music re-crystalization (or whatever they call it), but I wondered if I should just stick with my Barracuda AC-1. I currently have the Barracuda HP-1 connected to the HD-DAI port and my surround sound system connected to the digital out. I am toying with the idea of ebaying off the AC-1 and HP-1 headphones, and using my Sennheiser headphones that I connect to my surround sound and a desktop or clip-on mic of some type, at least until the Megalodon comes out and I see some info on it.
That's all my questions for now. I have a bunch of parts being delivered tomorrow to play with, and I can't wait to get off the wife's old computer and back into a gaming PC (my old Athlon 4400 which was due for an upgrade is a dead hunk of metal on my floor at the moment with lots of pretty scavengeable parts).
Thanks,
Lewis
Thanks,
Lewis
