Tom's Hardware > Forum > Motherboards & Memory > Memory > Kingston kyperx 2 GB DDR3 1800 problem
Forum Motherboards & Memory : Memory - Kingston kyperx 2 GB DDR3 1800 problem
Hello,
I brougnt a mainboard MSI GD70 winki edition , amd phenom II X4 955 and kingston ram 2 GB 1800
when i check bios for memory bus just got 1333 not 1800 also using Everest on windows 7.
and this is the ram spec :
http://www.elara.ie/products/detai [...] 38972#spec
also i found this page about this ram :
http://209.85.135.132/search?q=cac [...] en&ct=clnk
thanks in advance
regards
Sponsored Links
First off, did you check if your memory is fully compatible with your motherboard? In other words, is the RAM found within your mobo's QVL?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
Thanks for your replay r_manic
Yes . it's complitly compatible with MSI GD70 , also this mobo can reach maximum bus 2133 .
I found an article for solving this problem by overclocking this ram to reach 1800. but i don't know exactly how to over clock it . i tried to change those values on bios to 8-8-8-24 with average voltage 1.7-1.9
but didn't work.
could anyone tell me how exactly how to overclock it on MSI GD70 winki edition?
Reply to mhnassif
There are 1196 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
