Tom's Hardware > Forum > CPU & Components > CPUs > PCU Usage hovering around 25% please help
Forum CPU & Components : CPUs - PCU Usage hovering around 25% please help
I have a very fast custom built PC with 8 GIGS of RAM however sometimes my CPU usage starts hovering around 25% even though there are no processes using memory in task manager. This is causing a problem when I try and play games it makes the games lag really bad. It seems like this happens randomly and usually goes away when I restart but now the restart doesn't work.. it's still doing it.
I'm using Windows Vista Ultimate 64bit
I can't for the life of me find out what's causing this lag... it doesn't look like my AVG is running anything either.
Sponsored Links
Look in task manager to find out what is using the CPU time. Make sure you have the "show processes from all users" box checked.
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
Like I said... I've looked through task manager already and there is nothing that jumps over 2% and yes it's showing all processes from all users.
Reply to Fletch206
- 0 +
You've got some software conflicting, I'm pretty sure. Could also be a bad driver. I had that happen to me a few years ago as well and couldn't positively figure it out either. But I seem to recall uninstalling software until I found the conflict and CPU went back down. (but I don't remember for sure)
Reply to p05esto
- 0 +
You can sort your process by %CPU usage. If you have 4 processes at 2% each, there is your 8%. Just do it and find out where it's going. Then determine if you need those processes.
------------------------------ "He is no fool who gives what he cannot keep to gain what he cannot lose" -- Jim Elliott
Reply to leo2kp
- 0 +
Download and run Process Explorer - It's basically Task manager on Steroids.
http://technet.microsoft.com/en-us [...] 96653.aspx
It *will* tell you what processes are using what resources.
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
Thanks for the link Scotte
Reply to Fletch206
There are 1067 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
