NEED HELP.. Antec 902 FRONT PANEL AUDIO STATIC
Hi everyone.
I recently bought the Antec 902 case to replace my old modded cheap one..Problem is whenever I use the front panel audio out jack, I hear an irritating continous static. The rear I/O panel audio jacks does not share the problem.
What's causing this static? Is there any way to fix it?
Any help will be appreciated.
Um, i would say check where the front panel cable hits the mobo as well as check the cable itself. have u tried with different output devices? I know this probably isnt advised but turn on the comp and play like a song or something with speakers plugged into the jack. Flex the cable all down its length and see if it gets better or worse. Might work.
