Won't begin start up even after full parts/connector inspection.
Here's what I bought: (if you see a compatability problem, let me know... all of it should work together just fine)
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500 - Retail
pqi TURBO 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5400) Dual Channel Kit Desktop Memory Model PQI25400-4GDB - Retail
COOLER MASTER UCP RS700-AAAAA3 700W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS SILVER Certified Power Supply - Retail
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Retail (she's beautiful and HUGE)
ASUS V52 92mm Sleeve CPU Cooler - Retail (plus silver Thermal comp)
I have the CD/DVD Rom drives from the old PC transfered into the new Coolmaster case. Also I just bought a new HDD a month ago and transfered it to the new tower.
Here's the deal, I got it all in. It was all hooked up properly. I push the power button on the case and it slowly revs..revs...revs.. and then shuts off. I have no idea what the problem here is. I can't find a problem anywhere. I've removed the PSU and put in another from the old PC I was replacing (550 watt). That one imediately shut down and didn't even rev. So, I systematically remove possible componants (CD/DVD drives), leds, case fans and the like to see if that's the problem, still no love.
I'm about ready to throw something here. This isn't my first build, and I've modded almost every PC I've ever owned, but this $#%@& is driving me crazy people. If anyone has a decent idea as to what is going on (or not able to go on) I'd really appreciate the assist.
Thanks
System Specs
Budget: VGA:9800gt nvidia Monitor:
MB:gigabyte OS:win xp home Browser:
CPU:intel core 2 duo Sound:sound blaster CPU Pps:home, gaming, light small business
Memory:ddr2 667 PSU:700watt HD: WD 500gig Cooling:asus
Thanks
System Specs
