Closed Solved
Overclocking my cm5570 ap002 motherboard help
http://www.tomshardware.com/forum/260954-29-asus-essentio-cm5570-overclocking-guide#t1880389
using this step by step guide I am trying to update my bios, when I use asus EZ flash 2 I get the error
"the id in the rom file is invalid"
and when I try to open it with msdos and use afudos to update it says error:cannot open ROM file
Operating System: Windows Vista™ Home Premium (6.0, Build 6001) Service Pack 1 64bit(6001.vistasp1_gdr.100608-0458)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer INC.
System Model: CM5570 AP002
BIOS: BIOS Date: 06/02/09 10:09:38 Ver: 08.00.14
Processor: Pentium(R) Dual-Core CPU E5300 @ 2.60GHz (2 CPUs), ~2.6GHz
Memory: 6142MB RAM
Page File: 1614MB used, 10782MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
tjose are my system specs. I also have no overclock setting in my BIOS setup iH vae version 0208 and I tried getting the BIOS for the motherboard from asus.com but it doesnt work. could the bios be locked by pins? what can I do?
4 answers Last reply Best Answer
More about overclocking cm5570 ap002 motherboard help
  1. Best answer
    How are you typing it in DOS?
    afudos/iNAME.ROM/pbnc/n?
    i have had to put spaces into the command string before to get this to work with other motherboards. try placing spaces i the string
    afudos /iNAME.rom /pbnc /n or
    afudos /iNAME.rom/pbnc/n
    mess around with the order that is in and it should work.
  2. A better and easier way would be to download from the Asus website , the Asus Update utility, or , install it from you disc which came with the Mobo.
    Run it, after you've downloaded the BIOS you want to update your mobo to, point/browse to the directory where you saved it thru the Asus Update and let it do the rest....
    Simple, Easy, Fast and very reliable.....And really after updating 100's of Bios I still feel this has been the most reliable one....
    Of course I never vouch for the setting in the update utility that says directly from the internet...
  3. Best answer selected by cacoulte.
  4. This topic has been closed by Mousemonkey
Motherboards BIOS Overclocking
