Hello, I need help, I recently installed in my case 3 case fans, because the others were old, generic, making noises..., but the new temps aren't good at all, the cpu (AMD 955 stock cooler and clock) stays in 55ºC sometimes hits 57ºC the gpu (Sapphire 5770 stock clock and cooler, no egg, no cubic) idle 47ºC and gaming yesterday touch 81ºC the case fans are Evercool SFF-8 and SFF-12 mounted without filters (the spidermans), i got one 80mm on the case front pulling air to the inside (the HD is on the middle), one 120mm in the side of the case pushing air for outside (its barely in front of the gpu) and the last one 80mm its on the rear pushing air outside too (under the PSU).
Others: also installed another stick of RAM (total 3 sticks) and a DVD Burner the same time as fans, temps checked with CPUID HWMonitor, the fans are working perfect.
Help! I don't want to fry my card and cpu
