Hi all,
After searching the web for some time I could not find which parts are most important for RAW processing of images? Should I invest less on CPU power and put the rest for a faster memory or maybe it's the other way around? What benefits does a fast HD yields? Does Adobe ACR (Bridge or Lightroom) benefit from multiple cores when processing images? Does CaptureOne 4 benefit from multiple cores? How important is a strong graphics card for RAW processing? Please note that most of the work won't be done on Photoshop so it is less important to me how long applying a certain filter would take.
Here are a few observations I made while running some diagnostics during RAW editing/processing:
Software used: Adobe ACR/Bridge
Camera: Nikon D700 (14 MP RAW files)
System: Pentium 4 630 (3 GHz), 2GB DDR2 memory
Time for preview (~1000x800 pixels): 2-3 seconds
Time to convert RAW to JPEG: ~10 seconds
Running diagnostics while ACR and Bridge where running revealed that both programs allocated about 100 MB of memory for each image processing and while processing, CPU load was 100%. I also found that HD i/os where performed only on image save (after processing ended).
I am aware this is an old PC but if Adobe ACR or CaptureOne 4 won't benefit from multiple cores I can't see the benefit of upgrading (3Ghz is fast and the memory never reaches 100% usage). My primary goal is to get preview time as low as possible (less than one second). Second goal is to lower RAW to JPEG conversion time (waiting half an hour for a batch to finish is both time consuming and annoying). All other benefits for improving digital processing workflow are also welcome but I don't plan investing much in it.
Thanks,
Omer Yair
http://www.oyphoto.co.il
Thanks,
Omer Yair
