No you cant do that. Its possable that you could run it on two 6 pin cables but i dont know enough about it im afraid but definatly dont do what you are saying.
No. Its called a CPU power cable for a reason. They carry different currents off different rails of the PSU.
You can use the two 6pin PCIe cables for the card but overclocking will be disabled from my understanding. Or just do as rags suggest and disable crossfire before you open any games.
Message edited by spathotan on 04-04-2009 at 06:51:11 PM
I may be wrong, but i believe you can modify an existing 6 pin cable into an 8 pin one and it will work. Don't take my word on it and definately don't mess about with a psu unless you know what you are doing.
------------------------------I'm a git, deal with it.
