Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > PC will not boot (no power) but I do see some lights on.
Forum Motherboards & Memory : General Motherboard - PC will not boot (no power) but I do see some lights on.
So I opened it up to clean out the dust, like I have a million times and after putting it back it's completely dead other than the cat5 connection light and a green light on the bottom left side of the mobo.
No idea what I did but everything seems to be connected fine.....
Anyway, I'm guessing it's probably the PSU...or mobo but I don't know crap about hardware.
Any ideas?
Sponsored Links
What did you use to clean out the dust?
Reply to MaDMagik
So if i understand correctly when you press Power button nothing happens, right?
Did you remove any components before dusting or did you just blow the air inside the case?
Check the power, power led, reset and hdd led cables again. If theyre definately plugged in correctly than unplug the power one and touch the two pins with something metallic(screwdriver, knife) just be careful not to touch anything else.
If it doesnt help than go through the whole checklist jsc linked above.
Reply to MaDMagik
There are 1105 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 16:28 bilbat won the Motherboards badge
  • 01:00 jayhsyn won the Freshman badge
  • 01:00 nesta13 won the Freshman badge
  • 01:00 petar won the Freshman badge
  • 01:00 sinsear won the Freshman badge
  • 01:00 UnawareAtol won the Uniformed badge
  • 01:00 buryaku won the Uniformed badge
  • 01:00 Redras0324 won the Uniformed badge
  • 01:00 dvdmania won the Uniformed badge
  • 01:00 ugotomega won the Uniformed badge
