I just build a system that is acting pretty strange... when i power up the computer it powers up for a split second then turns off. I get no beep codes, nothing!
Components are as follows:
- q6600
- CoolIT DM-1000 Domino A.L.C. CPU Cooler
- asus pk5 deluxe
- 4gb ddr2 1066
- 580W atx power supply
- geforce 5200 (pci) video card
The first thing that pops into my mind is your CPU is over heating or the PSU is dying/dead. On my AMD system the latch that held the heatsink down onto the CPU somehow cane undone and was no longer making any contact with the mobo. Now, in this scenario my computer could normally get to the windows loading screen before it would shut off.
You could also try running the PSU when it not connected anything at all (not 100% sure if that safe or not though, I'd make sure the PSU if off when you plug in the power cord since it will turn on by default if the jumper isn't present).
Message edited by MykC on 03-12-2009 at 07:03:46 AM
No, your problem is that you bought a complete POS. Your going to have to spend a lot more than that. I hope you didn't blow anything up. What were you thinking?
You may also have a short. That would be the typical cause of your problem, but with that complete garbage PSU there is no way to know.
Another +1 for Zorg, and for Shadow's recommendations. It need not be high wattage, but high quality is a must. An Earthwatts 380W PSU would be sufficient.
You just built this system? With a PCI video card? A 5200?
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
I've never heard of a motherboard that has a 6-pin power connector. The CPU power connector will either be 4 or 8 pins. Most motherboards with an 8-pin CPU power connector will run fine with a 4-pin power connector plugged in. Just be sure to read the owners manual to see which pins to plug the 4-pin connector into. It's usually the 4 pins closest to the CPU socket. Here's a checklist for further troubleshooting if you need it:
