Hello guys, I'm looking for a water cooling system for my new build. I need it be able to cool a core i7 925 and a GTX 285, I need it to fit in a cooler master scout case, I need it to be silent, and reasonably priced. I'm not planning on over clocking too high, so I don't need a very powerful water cooling system. This is my first time buying a water cooling system, so any help is appreciated, and remember need it to be silent.
P.S: I need help finding water blocks for the two components also, thanks again.
Then you don't need it. Modern 120mm-class heatsinks can give you plenty of overclocking headroom for Core i7 already with acceptable noise level.
A proper CPU+GPU loop costs in the range of $300-350. Case modding for radiator is required if mounting internally. Basically it takes a lot of effort for a small gain over aircooling. Pre-made solution like CoolIT's range of craps perform worse than the best aircooling.
Message edited by wuzy on 06-13-2009 at 11:18:00 AM
------------------------------GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
Reply to wuzy
Yeah, I'm planning on spending over $500 just for the water cooling system to run silent becuase I'm not going to buy a new computer every day, so why not build something good. The Core i7's fan noise isn't the main problem, its the GTX 285's fan, because even if the fan is running at 50%, its still loud as hell. Not to mention how hot it gets at 50% fan speed
over $500. that's a waste of money, if you wont overclocked too high you dont really need water cooling. also water cooling required you to change the fluid after sometime and it requires maintenance.
