2 ide + sata drive problem
Last response: in Storage
- Problems replacing SATA boot drive with IDE Forum
- SolvedWill a R-driver III usb 2 0 to sata/ide cable work with a 3 5 floppy drive Forum
- SolvedHard drive speed too slow - SSD, USB 2.0, IDE, SATA Forum
- SolvedProblem with IDE/Sata drives Forum
- I have 2 IDE ports and 2 SATA ports on my motherboard, but I've got 2 SATA HDDs and 1 SATA DVD Drive Forum
- Problems doing a clean Windows 7 install from (second) Sata DVD drive - not the main IDE DVD drive Forum
- GA-EX58-UD3R, Sata hard drives and an IDE disk drive problem Forum
- Can you run 2 optical ide drives and 1 dvd sata drive together Forum
- Will an IDE DVD drive work (w/adaptor) in a sata2 port? Forum
- Hard drive in Sata 0, but comes up in BIOS as IDE Channel 2? Forum
- Has 2 IDE Slots for IDE Hard-drive And DVD Rom Drives how to connetct the sata h Forum
- SATA Vista, IDE WinXP dual boot problem - 2 different HDDs-- **SOLVED* Forum
- IDE->SATA DVD drive problems, 4 pin connector doesnt fit. Forum
- SATA HD and 2 ide HD's problem Forum
- Sata drives recognized as IDE PROBLEM Forum
- HP A1240N, Windows 8, 2 SATA Drives, 2 IDE Drives Forum
- Asus P6T problem with SATA and IDE drives Forum
- 2 drives on sata to ide connector Forum
- SolvedCan I run an IDE HDD with a SATA DVD/CD-R Drive? Forum
- Refurbished SATA HDD vs. 2 PATA/IDE Drives Forum
- More resources
Read discussions in other Storage categories
