4 GTX 295s or 4 HD 4870x2s (8 GPUs total) would probably overload a 1KW unit at full load. Of course, since 4 GPUs is the most supported by drivers, I don't see why you would ever have that.
Exactly, the other 2 cards would be at idle the entire time, unless you make custom drivers. My system only pulls 800w from the wall when running prime95 and 3dmark Vantage.
There are Folding rigs with 4x GTX295 or 9800GX2. The drivers support 8 GPUs, just not in SLI.
There is no such thing as 8 GPU's support 4x GTX295 is 4 GPU's, 2 GPU per card, meaning 2 GTX295 is quad SLI since a GTX295 has 2 GPU's in one PCB...unless i misinterpreted your question
QFE - Both nvidia and ATI drivers support 8 GPU's - just not SLI..
You may have a CUDA enabled app and love the performance 4 x Asus MARS (aka 8 x GTX285's) would offer - I am not sure that 1500kw would be enough for some people....
Perhaps if your using an extended ATX case and put in 4 x 4890s, using a really high vcore on a Phenom II, have 6 hard drive Raid array, tons of case fans, more lights than a christmass tree, 4 blu ray burns and you plan to burn stuff with them all at the same time, and hook up a toaster or coffee maker to it, then I can see a case for such a PSU .
------------------------------Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
I would certainly hope that 1500kW would be enough for anyone. After all, that's 1500 1kW PSUs...
On a more serious note, I think 4 Asus MARS GTX 295s would run fine on a 1500W PSU.
------------------------------Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
There is no such thing as 4 GTX295s!! That would be 8 GPU's and nothing supports that yet, hardware nor software! 2 GTX295's is 4 GPU's.
Yes. As I already stated there are Folding@home rigs with either 4x GTX295 or 9800GX2. There are various mobos with 4+ PCIe slots and the drivers support 8 GPUs. They do not run in SLI mode.
For gamers, 2 GTX 295s is the best - drivers don't support more than 4 GPUs working together for a single monitor. 8GPUs (4 GTX 295s) is only useful for driving a whole bunch of monitors or for something like Folding@home.
Reply to cjl
maybe someone has an amplifier in their pc to run their home theater while using a super overclocked i7 using a phase change cooler and 4X GTX 295s to run folding@home at the same time.
SLi only allows for 2 GTX295, so for gaming thats the max setup.
However, so long as you have 4 PCI-E slots, theres nothing stopping you from loading up a mobo with 4 GTX295 for the purpose of GPGPU applications such as folding.
