Tom's Hardware > Forum > Homebuilt Systems > New System Build > First System Build Need advice on Everything
Forum Homebuilt Systems : New System Build - First System Build Need advice on Everything
So my previews post i did not really put i any info on what i needed and what i didnt need so this one i'm going to try really hard on the infos.
I have a budget of $1250
Uses:
Multi-tasking- having lots of applications and windows open usually running all at full speed.
Video Editing- Video conversion, ripping, maker
Lots of Gaming- i havent really played with games like crysis or anything i like that but will probably will in the future when i have time.
Watching movies and videos- I'm going to connect my computer to my 42" 1080p tv and probably be my main screen. i watch lots of movies on my computer so the better resolution i get the happier i am.
Overclock- yes i will overclock my pc just to get a use of my money. I have no idea whether to go with core 2 quad or i7 or what so ever so i need a suggestion on that.
Hard drive- Also I need a suggestion on whether i should get both ssd and an hdd i would like to know the benefit i go for both. i would like fast boot up speed and fast file access.
Crossfire and sli. i'm planning on doing it in the future but not right not so the best gpu i can get would be best for now
Cpu- i dont know what to get for my needs but like i said i would be overclocking.
ddr2 and ddr3 whats the difference and benifits.
thats all i can think of for now
Message edited by udxjambaki on 03-13-2009 at 07:07:36 PM
Sponsored Links
I'm working on one for ya now. :)
Message edited by Why_Me on 03-13-2009 at 07:53:14 PM
Reply to Why_Me
ill be using my 42" tv
Reply to udxjambaki
preferebly through hdmi
Reply to udxjambaki
http://www.newegg.com/Product/Prod [...] 6811119137 $79.95
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6817341011 $109.99 ($99.99 after $10.00 Mail-In Rebate) Free Shipping*
PC Power & Cooling S75CF 750W EPS12V SLI NVIDIA SLI Certified (Dual 8800 GTX and below) CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6813128358 $134.99 ($114.99 after $20.00 Mail-In Rebate)
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6819115041 $274.99 Free Shipping*
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6835233029 $39.99
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail
http://www.newegg.com/Product/Prod [...] 6814102801 $199.99
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6820231209 $43.99 Free Shipping*
G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6822136319 $79.99 Free Shipping*
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6827136152 $24.99 Free Shipping*
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner - OEM
http://www.newegg.com/Product/Prod [...] 6832116488 $99.99 Free Shipping*
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
http://www.newegg.com/Product/Prod [...] 6835186020 $6.99
ARCTIC COOLING MX-2 Thermal Compound - Retail
Total: $1,095.85 *(not including shipping and rebates)
Reply to Why_Me
any other plz note why one is better
Reply to udxjambaki
This is the i7 version of that build. Switch out the mobo, cpu, and memory of that bulid with this down below and your somewhat future proofed. :)
http://www.newegg.com/Product/Prod [...] 6813130221 $189.99 ($169.99 after $20.00 Mail-In Rebate)
MSI X58 Pro LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6819115202 $288.99 Free Shipping*
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6820227365 $109.99 ($89.99 after $20.00 Mail-In Rebate) Free Shipping*
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory - Retail
Total: $1,230.85 (not including shipping and rebates)
Message edited by Why_Me on 03-13-2009 at 10:10:16 PM
Reply to Why_Me
+1 for the i7 build, much more future proof, and would fit the OP's need.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
whats the difference between Core® i7 Processor 920 from microcenter.com priced at (229.99) and Intel Core i7 920 Nehalem 2.66GHz from newegg price at (288.99) whats nahalem? sorry im new to this
Reply to udxjambaki
"Nehalem" is the architecture name. I wasn't able to find the i7 920 at microcenter. There is no difference between the retail packages (doesn't matter where you buy it from).
There are 1342 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
