Yes No
Ads
Tom's Hardware > Forum > Overclocking > Heatsinks & Air Cooling > [Solved] Building water cooling system for 2 GTX 480, any advice?
Forum Overclocking : Heatsinks & Air Cooling [Solved] Building water cooling system for 2 GTX 480, any advice?
Best answer from rubix_1011.
i will make my own HOMEMADE case, large, because i want to place 2 radiators inside of my case one quad rad. to cool gtx 480 sli and triple rad. for i7 CPU.
here what i planing to get for my GTX 480s :
http://www.frozencpu.com/products/ [...] 30c107s155
http://www.frozencpu.com/products/ [...] ?tl=g30c95
http://www.frozencpu.com/products/ [...] ?tl=g30c97
http://www.frozencpu.com/products/ [...] tings.html
1/2 tube fore gpu and 3/8 tube fore cpu. liquid flow PUMP - from the bottom to 2ND GPU - 1ST GPU -RESERVOIR - RADIATOR - PUMP
ANY ADVICE ?
Message edited by matvey on 10-28-2010 at 01:28:44 PM
Reply to matvey
Res before pump, after that it doesn't matter.
Why 2 different size's of tubing ?
Reply to delluser1
^agreed. Why a MCP655 w/ 3/8" adapter kit? It is native 1/2" ID tubing...you'd want to run this for your entire loop if possible.
Reply to rubix_1011
^+2. The golden rule is res before pump. After that, moving around the rad,etc will only change the temps 3-8C depending on your heat load, flow rates, rads,etc.
------------------------------ http://farm5.static.flickr.com/4113/5052517574_1d0ebc741b.jpg
Reply to Shadow703793
@OP:
Are you planning to upgrade your GPU's at any point? If so, you might consider a universal block like the MCW80 and using RAMsinks for the RAM modules. A full cover block will work fine, but is more costly and won't work on the next series of card (ex. GTX580, etc) For the cost of 1 full cover block, you could almost get 2 MCW80's and the RAMsinks needed to complete that option.
You could also consider the Swiftech full cover 'plates' that go with the MCW80 block. Between the block and plate, you'd pay almost as much as a full cover block, but you can reuse the block and just get a different plate for the next series of card... buy another $45 'plate', or buy another $130 full cover block.
But, if you don't mind the price, full blocks are great; just do some research before you buy...not all perform the same.
Message quoted 1 times
Message edited by rubix_1011 on 10-28-2010 at 06:14:13 PM
Reply to rubix_1011
^ Good point.
Just thought I'd offer up some alternatives if the OP decided to get different hardware in the future...which is what a large percentage of all of us do...
Reply to rubix_1011
[quotemsg=1881069,2,132889]Res before pump, after that it doesn't matter.
Why 2 different size's of tubing ?[/quotem
i already have a loop with 3/8 fore my CPU and it is easy to work with 3/8 than 1/2. or you think it is better to change it on 1/2?
Reply to matvey
RES-PUMP-RADIATOR-2ND GPU-1ST GPU- RES is it fine?
Message edited by matvey on 10-29-2010 at 12:10:25 AM
Reply to matvey
rubix_1011 wrote :
@OP:
i agree, but MCW80 and using RAMsinks is not good fore SLI, IT WILL BE NOT SO EASY TO BEND 1/2 . am i right? and i will wait for 580 card, and I also read that NVDIA will release new cards after new year.
Message edited by matvey on 10-29-2010 at 12:18:05 AM
Reply to matvey
and also i want to know is quad rad. will be good to cool 2 GTX 480 or i need some thin extra?
Reply to matvey
I run SLI GTX260's with MCW60 blocks and RAMsinks. It would be almost the exact same setup as I described for you, just different block models (the MCW80 is the newer version). Where do you get your info?
Yes. It is very possible to bend if you get tubing with good flex properties, such as Tygon or Feser...there are others as well.
Reply to rubix_1011
but for RAMsinks i would need a good air flow in the case or it is not necessary? price is not a problem, i think that full block is still better.
Reply to matvey
If price is no issue, then sure, go that route. If you have a case with good airflow, you would be fine in most instances with RAMsinks. Your call, just providing as many options as possible for you to make an educated decision for yourself.
Reply to rubix_1011
thank you for your help. quad RAD will be enough to cool 2 gtx 480 ??
Reply to matvey
Best answer
Likely, but it depends on what fans you get for the rad you choose. You will either be right at threshold, or have some wiggle room depending on your rad/fan choice. In most cases, my rule of thumb is minimum 1 CPU or GPU per 2x120 radiator surface area.
Check out http://skinneelabs.com/ for details on all things watercooling as far as benchmarks and tests.
Are you running a single loop, or separate loops for CPU/GPUs?
Reply to rubix_1011
i will run separate loop one is for CPU triple rad and one fore 2 gtx 480 quad rad
Reply to matvey
There are 1897 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Any news on the Thermaltake Water 2.0 Extreme Cooler?
By amuffin, 14 hours ago:
If it has anything to do with Thermaltake, it's a BAD IDEA.
Best offers
Top experts
