Tom's Hardware > Forum > CPU & Components > CPUs > Best CPU Temperature Monitor?
Forum CPU & Components : CPUs - Best CPU Temperature Monitor?
I already know of Speedfan, Everest Lavasys, and of course the ever-trusty(?) BIOS... what do you guys use to monitor CPU temps? Which is the most reliable in your opinion? :)
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Sponsored Links
i personally really like speedfan but it's for the more experienced. it measures individual core temps gpu and fan speed
Reply to TheMan1214
Hi R
I prefer RealTemp, CPU and GPU temp monitor with alarm.
Reply to starams5
Best temp monitor would be a sensor placed inside the CPU itself. I don't think any of the current software is 100% accurate, but personally I prefer RealTemp.
------------------------------ Antec 1200 -=- Corsair HX1000 -=- GA-X48-DQ6 -=- Q6600 @ 3.2 GHz -=- 8GB RAM @ 800 MHz CL4 -=- 4870X2 800/1000 -=- 2x 500GB 7.2k RPM -=- 150GB 10k RPM
Reply to Kraynor
Where do you think Real Temp reads the temperature from? ;)
Reply to randomizer
The DTS that provides figures relative to a TJ-Max, the sensor I'm on about is opening the CPU, putting in a thermal sensor that gives an absolute value output that doesn't have to be subtracted from a guessed figure ;)
Reply to Kraynor
I recommend coretemp for processor.
Reply to Janti
Well in the case of i7 it's not a guessed figure. Tj Target is stored in a Model-Specific Register, and unlike Core 2 it's actually quite close to the real thing on most CPUs.
Reply to randomizer
RealTemp is the most accurate in terms of 45nm 775 CPU's I believe.
Reply to brendano257
Real Temp is just as "accurate" as anything else (meaning not accurate) if you don't calibrate it. Speedfan is accurate if you calibrate it according to this guide: http://www.tomshardware.com/forum/ [...] ture-guide
Reply to randomizer
Thanks for the link, I found the Tcase/Tjunction useful.
Reply to starams5
It is the most comprehensive guide of its type anywhere. Last i was told (a few months ago) it had almost 2000 hours of research put into it.
Reply to randomizer
i dont recomend coretemp,....
i found in speedfan my temp as 23 in idle same with occt in idle and in bios 23-24 idle,..
then i found in coretemp that my idle temp is 45,.....
maybe if the bios temp is the same with core temp i might believe that speedfan and occt are the does who inaccurate,.. but man the bios,....
ofcourse its the most reliable because its bios man...
speedfan=5/5
occt=5/5
bios=5/5
coretemp=0/5
Reply to Testgamma1
Er... no. Read the temperature guide: http://www.tomshardware.com/forum/ [...] ture-guide
Reply to randomizer
There are 1343 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
