Simple question, basically. My friend was asking my what cheap good card he could get so I recommended a GTX 260. So he ended up buying one. Today he complained that it wasn't running Team Fortress 2. or at least was only running it at around 40fps maxxed out. I thought it was odd because I have a GTX 260 and I max tf2 at a solid 60fps. I took a look at his PSU and it's only 600 Watts with 18A on the 12v rails, and the 260 requires 36a on the rails and at least 500 watts. He bought a better power supply last night. But simple question.
Could playing without enough power for it damage the card or just cause slowdown in games?
Message edited by delti90 on 04-06-2009 at 09:50:31 AM
I would have thought that 18A is off each PCI-E connector (36A combined) if it's 600W system.
Mainly it depends on the quality of the PSU, good quality ones have much better efficiency ratings. I'm running my GTX260 on a corsair VX450W without any issues at all.
If the PSU wasn't delivering enough juice the PC would crash/shut down. I suspect that other issues are occuring here. Using the latest drivers from Nvidia?
If you provide full system specs we might be able to work out what going on...
edit here are the specs:
AMDx2 ATHLON 6000+ (clocked at 3.0ghz)
4gigs ddr2 ram
evga nvidia gtx260
ASUS M3N-HT DELUXE
he just bought a corsair 850 watt psu with 70a on the rails but it hasn't come yet.
You have made the right choice to change the PSU whatever happens, Coolermaster make poor units which have been shown not to deliver their rated wattage and current.
Yes, it is possible to damage the system if it is run underpowered and yes it may very well underclock under those circumstances although it`s just as likely to crash while running or simply fail to boot.
The new Coolermasters are supposedly better, but that's an older one and a good idea to replace anyway. Corsair is an excellent choice.
Still, there could be other problems at work here, like heat.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
4gigs ddr2 ram
evga nvidia gtx260
ASUS M3N-HT DELUXE
You don't combine the voltage - you combine the amperage on both rails. So an 2 rails, e.g. 18A + 18A, gives you 36A total input for you're GTX, but the voltage is still 12V for both rails - this effect doesn't add up because of the way voltage (electrical tension) works. If you know you will be running 36A on 2 rails you need to look at the max amperage rating for all of the 12V rails. Then you need to know if the 36A + the amount of amps you CPU and anything else on other 12V rails exceeds the max total amperage rating (e.g. if the max total rating for all 4 12V rails is 41A:
41A -36A = 5A, then you only have 5A left for you're CPU and anything else running on a 12V rail before you max out)
As for the 850TX it is a brilliant PSU, a bit overkill for the system its running but plenty of room to upgrade - you could probably SLI with 2 GTX 260's in the future (kinda guesstimating there)
Message edited by nerrawg on 04-06-2009 at 03:26:46 PM
Well the PSU hasn't arrived yet so we don't know if that was causing it. But when playing COD4 for some reason it runs at a solid 60fps. So maybe it's a problem with TF2 in itself.
