I am planning on overclocking an i5 750 to a minimum of 4 GHz. This is going to be my first build so i don't want to spend the extra money going watercooling because if i mess up then a lot can go wrong. I've been doing a good bit of research and so far I have got it down to about 3 fans+heatsinks. I am going to be using an antec 1200 (not sure if this case is overkill size wise but I think it has the room for if I upgrade to watercooling later on).
Here are the three air cooling systems i am thinking about:
Noctua NH-D14 120mm & 140mm SSO CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
Prolimatech Supermega Intel Socket 1156, 1366 and 775, 6 Dual Heatpipes, Twin Tower CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835242006
Prolimatech Megahalems Rev.B CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835242001
The last two do not have fans...I really am not sure what fans to get, but I want go more for efficiency and powerful cooling than a ridiculous silent system. As long as its not overly loud I wont mind.
Thank you very much for any suggestions and comments!
