hi,
i was wondering how you could make the ARCTIC COOLING Freezer 7 would work with the i7. I've seen brackets from other brands that let the older sockets work with the lga 1366, could any of those work with the Artic Cooling?
Most boards won't advertise that feature. You'd have to look at pictures of the socket area. If you look at the sample I listed, and view the motherboard, you can see two mounting holes on each of the four corners.
