Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > What rating would you give a antec true power 1000w?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - What rating would you give a antec true power 1000w?
i'm planning to buy that power supply unit for $329.
i'll be having a 4 x 1tb sata hard drive, 2 or maybe 3 video cards, my case has built in fans (cm 932), a cpu cooler, blu-ray drive
q. out of 10 what rating would you give the antec?
note: should i stick with the antec or maybe change to another brand?
help needed, thanks in advance
Sponsored Links
Hi V
I have two 1000w TPQ's, had no problems with 4 SATA drive's. I backed off 4 HDD's because they were blocking the intake resulting in high MB temps, something you might want to consider. I have one TPQ that is approx 2 yrs old and the other a little over a year, haven't had any problems out of either. I would buy an Antec again without giving it a second thought.
Message edited by starams5 on 06-17-2009 at 09:06:54 AM
Reply to starams5
- 0 +
I like antec also. But I doubt you need 1000 watts. 800-850 units will cost considerably less and provide adequate power. I would use a case with a lower bracket and mount all your hardrives behind a large 120mm fan for adequate cooling. For what you're spending, seasonic has the best warranty; up to 5 years and they manufacture some of the other branded high end power supplies.
Reply to o1die
What other options do you have in your price range?
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
- 0 +
Fry's stores has the antec 850w quad for $149.99 in today's ad, for example. Newegg has the pc power and cooling 910w silencer for $183.99 with free shipping, or the seasonic 750w M12D for $180 after $30 rebate. Either one should be adequate for your system.
Reply to o1die
www.pccasegear.com
- cooler master real power 1000=$365
- seasonic m12 850w=309
- corsair tx-750w=$219
- thermaltake 1500w=$499
Reply to famciclovirrr
Corsair HX750 & 850 have a 7 year warranty.
HAF 922 | HX750
Reply to theAnimal
There are 529 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
