Hello i have a system with a AMD phenom x3 8400 2.1Ghz.. It currently runs at 2.52Ghz thats the highest i can get with just pulling up the buss speed to 240 and the voltage to 1.2625.. Ram runs at 960mhz too with voltage at 1.99.. runs stable i have tested with prime95 highest temps i get are 28c at 100% in 18 hours with an NorthQ 3580 water cooled cpu cooler..
So my question is if i can overclock it higher i havn't touched the "HT link, nb frequency.." just the bus speed.. I once changed something of it a little and got it booted into windows with 2.58ghz but i could not get it stable. could anyone of you tell me what the "HT link, Nb frequency..." or just anyway i could get it higher if possible
I am thinking of an upgrade to a 1055T because the CPU really bottlenecks my Ati 4870 :
Thanks - Rani
Thanks - Rani
