Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will this GPU fit inside this case?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will this GPU fit inside this case?
Hey all
I would like to upgrade my graphics card to a Geforce GTX 275. I have a screen with a native resolution of 1920x1200 and according to my research this card would allow me to play games with a lot of details (correct me if I'm wrong, I have a very good system).
Anyways,
I would like to order one of these cards on line, but I need to know which brand will fit my case: Antec NSK6580B Black [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16811129045][/url]
I previously ordered a Geforce 8800 and it would not fit in the case -- it was too big.
I currently have an EVGA Geforce 9400 GT which fits fine, but can't run anything on such high resolutions.
Any advice would be much appreciated.
Sponsored Links
The GTX 275 is about 10.6 inches long and longer than the 8800. Have you checked the case to see if you shuffle, move (or remove) the storage tray forward?
Reply to HundredIslandsBoy
well, best bet is remove the storage tray and get a mount kit for your HDD for the ODD bay (5.25 bay), then you should have a lot of clearance, though with more than 1 HDD this might be a problem though
Reply to mindless728
There are 1249 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
