Well i have just overclocked my CPU from 2.5GHz to 3.2ghz, with FSB speed goin from 333mhz to 430mhz (7.5multi (max)) and its causing slight ram instability, aprox 1error every 300% memtest. Vcore 1.3v
If the fsb is turned up more then the frequency of these errors increase but in all the frequencys that iv tried the fsb on (>400mhz and i would hate to go under this freq) it always comes up with the same ammount of errors.
The timing on the ram are auto, aswell as the voltage, the freq 1280 (roughly cant remember exactly what value) with the next value something around 1720 which causes boot failure even though memory is rated at 1600.
also if there is other key info which i have missed out pls highlight and i will get back to you with an answer.
My main aim is to get a 100% stable OC, i dont wana do a half assed job.
Is there any reason / fix that you guys can think of or advise, it would be much apreciated.
Ryaz
Ryaz
