I am new here and I am building me a custom PC. I want to make sure that I have chosen some good parts before I by. If I could get some opinions that would be great.
My Build
2 x WD 640GB Black HDD
Zalman CNPS9900 CPU Cooler
Antec 1200 Case
Antec 1000Watt PSU
ASUS P6t Deluxe
i7 920
OCZ Gold 3 x 2GB DDR3 1600
BFG GTX 285 OC (already bought)
APPROXIMATE PURCHASE DATE: the closer the better BUDGET RANGE: $1200
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, surfing the internet, watching movies, video editing and encoding
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS)
Thanks for the help and I will repost. Newegg had a $40 rebate with the Antec PSU that is why I was going with that. Do you think that the Corsair PSU is better?
Corair PSU should be better, I have a corsair hx-1000 on my i7 rig and its realy good, but I could of got away with the HX-750 (2x4870 1gb in cf). Rest of the build seems fine all though I would advise against the Zalman cooler, they had developed a good name previously but recent products have be very average in terms of performance. I would go with either a noctua U12P 1366 SE or if you wanted to save some money a scythe Mugen 2, I have a mugen 2 and its good, in fact is one of the best i7 coolers on the market but also one of the cheapest too, which is a very rare combination.
Thanks for the advice. I believe I will go with the corsair 750 and I will look into the those 2 coolers you talked about. What temps are you getting with that cooler underload and idle?
That is a great build. Those pics really helped me out. So far I think I will go with corsair 750, Xigmateck dark knight and I will be sure to add an 8 pin extension.
Sorry took a while to get back, at 3.8ghz im idling at 30-35 atm according to real temp and I get about 65 at full load on prime 95. at 3.5 on stock voltages was similar idle temps but not over 60.
anywaz sounds like you got it sussd, enjoy the new build!
Message edited by D3LTA09 on 06-21-2009 at 02:08:06 PM
Yea im pretty happy with it now but its taken a while to get it all sorted out. Thats right im using a scythe mugen 2 and thermaltake v9 black edition case with 2x120mm fans at the front 1 at the back, 230mm at the top and have the case open but thats for my gpus more than cpu as I have no choice but to have my soundcard in between them.
I say it took a while because with the mugen 2 you have 4 different options to mount the fan or fans (1-4 120mm's) and 2 different ways of mounting the cooler. At the moment I have the fan mounted on the exhaust side of the heatsink in a pull config as my ram heat spreaders dont allow my to have it as a push set up on the other side. Previously I had it mounted underneath on my gpu side if that makes sense pushing air out the top to my 230mm fan but I got about 3-5 degree drop by moving to the aforementioned spot at full load (idle roughly the same).
Im waiting on arrival of another higher CFM (standard one with mugen 2 is 70ish and order a 110cfm 1900rpm version) scythe fan 2morow so will see what a push/pull config or just a pull config with a higher CFM fan will do for my temps. Also waiting on a evercool 70x70x10 fan for my mobo tray as my case gives me option of a fan blowing directly onto the reverse side of the cpu chip, be interesting to see if moving the heat from the back of the mobo does much for temps.
I wont lie my setup is probably quite affected my fairly low ambient temps as its winter in my country (NZ) so prolly not gona be quite so good in summer Id say up in the 70s at full load so might go to WC then.
