Copy paste problem
Hello,
i copy a file from desktop adn then copy into a folder.then i open it later.the file is not open.read only error.
2 answers Last reply
More about copy paste problem
  1. You can try right click>Properties and uncheck Read only, and ok.
    You can also try copying it with cmd.
    Go to start>run and type cmd,
    Type cd C:\ and press enter
    Type copy C:\windows\Docum~1\Your_User\Desktop\Your_file_name.the_file's_extension C:\Your_folder and press enter
    But, I have to ask, does you original desktop file come from a cd? :hello:
  2. saravanakumar727 said:
    Hello,
    1. I assume you have ownership of the folder.
    2. Why not drag the file directly to the folder ?
    3. using cmd is completely unnecessary.
Desktops Read Only Windows XP
