Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > GTX 260 on 500w power supply?
Forum Graphic & Displays : Graphics Cards - GTX 260 on 500w power supply?
I am thinking of purchasing a GTX 260 and most say they require a minimum 500 W power supply with 12V current of 36A. I have a PC Power & Cooling Silencer 500 W that has a 35 A current. Seeing as how this is one of the best 500 W power supplies in the industry, should I be safe with only a -1 A difference or should I not risk it and downgrade to a GTS 250 or HD 4850?
Sponsored Links
Should be no problem running a single 260 on the Silencer 500.
Member "invisik" runs 2 of them on his Antec EA500
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
Thanks, guess I will pull the trigger!
------------------------------ Q9400, Gigabyte GA-EP45-DS3L, PC Power & Cooling Silencer 500W, 8GB OCZ Platinum DDR2 1066 Ram, MSI GTX 260 OC, Seagate 7200.11 750GB, M-Audio Delta 1010 PCI sound card
Reply to mkb5150
I am interested if you were successful. I also have a PC Power silncer 500 and looking into upgrading my GPU.
THanks
Reply to jsox99
There are 852 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
