Ati problem
Forum CPU & Components : CPUs - Ati problem
i recently purchased a xfx 4850 512mb vid card
i constantly got this error than vpu recover has reset your graphics in win xp
i am currently using windows 7 64bit and have the latest drivers installed and have done a mild oc of 660/1033 but when i play far cry2 the game after an hour or so just exits on its own or hangs and then shows me an error that drivers have stopped responding.
its driving me nuts how do i resolve this problem??
Sponsored Links
First, if youve got problems, stop ocing. Check your temps. Also, make sure your psu is adequate. A 4850 type rig, you should have bare minimum 30 amps on your 12v rails
Message edited by jaydeejohn on 06-19-2009 at 12:38:52 PM
------------------------------ I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
+1^
I used to get the same problem when ocing my sapphire 4850, though it was a bit higher than yours( 690/1060). I reduced the oc and problem went away, although I also noticed that running Folding@home would cause the same issue even on default clocks.
Reply to MaDMagik
ok here is my config
phenom II 940
corsair vx550
gigabyte ga-ma790gp-ud4h
cm690 case with 2 intake and 3 exhaust
i doesnt only happen when i play games
just now the screen froze for two seconds and gave me a message ati device driver has stopped has responding and has successfully recovered
i have put the clocks at default lets see what happens
any other suggestions?
Reply to sid_nag17
oh btw i currently have a stock cooler on my phenom but am planning to get a after market cooler. was thinking about the sunbeam core contact freezer.
my cpu runs really hot
idles at around 51c and on load goes upto 58c
ambient is around 33c
will i get any improvement with the aftermarket cooler?
Reply to sid_nag17
Yes to the cooler.
How bout your gfx card? Is it getting hot? Also, have you changed drivers lately? Is all your connects secure? Check those as well. Only other thing is psu, tho youve got a good one, it too couldve somehow gone bad. Temps for gpu first tho
Reply to jaydeejohn
51c idle on CPU?? Definitely need to check GPU temp as well.
Reply to roofus
no gpu idles at 46c and on full load goes to a amx of 61-63c which is quite acceptable i think.
all the connects are triple checked by me and its a brand new pc just two weeks old!
and will the ocz vendetta 2 be a better option to the sunbeam core contact freezer?
Reply to sid_nag17
oh i guess you guys overlooked my room temp is always above 30c goes to a max of 35c
Reply to sid_nag17
Yeah my room temp is about 80-82f. Its hot here.
My cpu idles at 48c and at 100% load is 60c. Those temps are fine. Dont worry about idle temps, only load temps.
I had the atikmdag error before and somehow I fixed it. Recently I reloaded windows and I've been dealing with the problem again, however I've read some forums and tried some things and its only happening about once a day now. One of the things I did was set it back to the factory OC settings.
------------------------------ P965/Q6700@3.2 8MB HD4850 OC Edition
4GB Corsair XMS 800
Vista64/Win7
Fatality 550w/Antec 300
Reply to zipzoomflyhigh
yeah i put it back to default clocks and now things are running smooth but only far cry 2 gives me problems the game after 1-1.5 hours suddenly exits!!!
and which cooler should i get??
Reply to sid_nag17
guys which one??? im leaning towards the ocz!
Reply to sid_nag17
Tom's Hardware > Forum > CPU & Components > CPUs > Ati problem
There are 969 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
