I bought everything and it got here today. I put it together with the best of my ability and the bios is beeping at me. I referred to the bios manual and the beep that I'm getting is not in there. I'm getting a BEEP.....BEEP.....(long pause).....repeat. I can enter bios and look around but the beeping continues. I looked at the post but it doesn't report any errors. I have built quite a few systems and never had problems hooking stuff up. Does anyone have any idea what's going on ?
Case:
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case
Motherboard:
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard
Video Card:
EVGA 017-P3-1293-AR GeForce GTX 295 1792MB 896 (448 x 2)-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card w/ Pre-installed ECGA Backplate
Power Supply:
CORSAIR CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Compatible with Core i7 Power Supply
CPU:
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920
RAM: (2 of these)
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model OCZ3P1600LV6GKl
Storage (OS Drives): (2 of these)
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM SATA 3.0Gb/s Hard Drive
Storage (Misc):
Western Digital Caviar Green WD10EADS 1TB SATA 3.0Gb/s Hard Drive
Monitor:
BenQ G2400WD Black 24" 5ms, 2ms(GTG) HDMI Widescreen LCD Monitor
CPU Heatsink:
COOLER MASTER V10 Hybrid TEC RR-B2P-UV10-GP 120mm CPU Cooler
Case:
Motherboard:
Video Card:
Power Supply:
CPU:
RAM: (2 of these)
Storage (Misc):
Monitor:
CPU Heatsink:
