Enable Power ssaving feature + Turbo when overclock?
Hello,
I haven't found any solution to my problem on google yet. I have a P7P55D-E with a i5-750 and everytime I try to increase the BCLCK, the power saving feature disenable and hide the turbo feature :(
I am wondering how to enable these with like 165+ BCLOCK.
Just want to note that I do want to do this even if you think it is a bad idea or whatever. The reason is that I need that as my summer set-up.
Thanks for your help!
2 answers Last reply
More about enable power ssaving feature turbo overclock
  1. Just a nickname said:
    Hello,
    what did mean u say 165+BCLOCK? :sarcastic: u mean overclock QPI Disable Turbo feature & increase Clock speed ? :pt1cable:
    Changhe Ai overclock Manual don't Auto in BIOS sorry...
    disable turbo is look in bios C1E must disabled Potition
  2. What I mean is, when I change my BCLCK above 133MHz, the speedstep disenable and hide the turbo feature. I can't enable it there.
    When I go into the CPU configuration, even if enable speedstep and other options like turbo, it go back to disenable option when I get out of that panel...
CPUs Overclocking Power
