C couggod Distinguished Oct 8, 2010 1 0 18,510 Oct 8, 2010 #1 When I connect my Toshiba external HDD to my computer through a USB male to female adapter, it makes a clicking sound. But when I connect directly to the computer with its supplied cable I get no problems with it, what's causing this?
chunkymonster Splendid Jan 12, 2006 3,672 0 22,960 Oct 8, 2010 #2 Have you tried using other USB ports? DO they give the same result; clicking? The USB port may not be supplying enough power to the drive. Also worth trying another USB cable, just to eliminate possibilities. Upvote 0 Downvote
KingArcher Distinguished May 19, 2010 238 0 18,710 Oct 8, 2010 #3 Use a Y-cable and connect two usb ports to the drive so that it gets more current. Upvote 0 Downvote
