Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > ##Power supply for Gaming pc##
Forum CPU & Components : Power Supplies, Cases & Mods ##Power supply for Gaming pc##
Hi im getting a custom gaming pc built and it says i require about a 500w psu for it
My specs are
amd Phenom II X4 940
Gigabyte 780G Motherboard
XFX Radeon 4870(1GB)
4GB 800mhz Ram
500GB Sata Hard drive (7,200 rpm)
(and then all the other stuff like vista ect....)
ive bought a case and im getting a person to build it but i was wanting to know will my power supply be ok for my spec
http://cgi.ebay.com/ws/eBayISAPI.d [...] gory=51063
there's a seller on ebay who has all the specs for it ....
600w PSU Details Thanx in Advance :) :)
Features---------------------------------------------------------------------------
High power 600w
Supports the Latest Technology:
Intel® Core™2 Duo, Intel® Core™2 Quad, Intel® Core™2 Extreme
AMD Athlon™ 64/x64FX, AMD Phenom™ , AMD Sempron™
Dual Core (Pentium D EE and Athlon64x2) & Dual CPU Systems
Seperate 12V rails meeting UL 240VA safety requirements
SATA Power Connector for connecting you system to the faster Serial ATA interface for better performance
Automatic Fan Control System
High Reliability, the following circuits ensure the systems safety:
OCP (Over Current Protection)
UVP
OVP (Over Voltage Protection)
OLP
OTP
SCP (Short Circuit Protection)
EMI Reduction Design
100% Burn-In Test / Hi-Pot Test /Vibration Test / Leak Current Test
Approved by UL, CSA, TUV, CB, CE, S, N,D,FI & FCC
RoHS Compliant
Specification
Input:
AC input Voltage: 95-132VAC or 190-264 VAC switchable
AC input Current: 8A res max. for 115VAC 60Hz, 5A res max. for 230VAC 50Hz
Overload protection :150%
Output:
+12V1 18A
+12V2 18A
+5V 30A
+3.3V 35A
-12V 0.8A
+5V/SB 3.0A
Reply to robert1037
Get a good quality PSU. Corsair VX550 or HX520.
------------------------------ 24 threads @ 4GHz
Reply to theAnimal
That is an absolutely terrible power supply. What matters more with a power supply is the amperage and the amperage of that 600w would be terrible for a 500w power supply.
Stick with a PC Power and Cooling, a corsair, or an Antec power supply.
Reply to The_Blood_Raven
There are 2017 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Cpu Temperatures higher than normal by a far margin !!
By rolli59, 2 hours ago:
If properly mounted!
Best offers
Top experts
