How much power is being drawn
I'm trying to figure what is the minimum PSU that would run a Phenom II 940 and GTX 285.
http://www.tomshardware.com/reviews/geforce-gtx-285,2139-9.html Does include the CPU draw or just the GPU.
4 answers Last reply
More about power drawn
  1. "Global wattage at AC source ".
    those are the figures at the wall socket
    the 316 watts for the 285 rig looks about right .
    Just because a cpu/gpu is rated at a specific wattage doesnt mean it will draw that much . Intels 65 watt chips typically draw half that under load
    see
    http://www.extreme.outervision.com/psucalculatorlite.jsp
  2. Cool, that is a very interesting tool (bookmarked)
  3. Its surprising how little power some systems need .
    I think Tomshardware e7200/G31 mb was drawing 70 watts .
    Even a quad core cpu and a GTX 295 system with a couple of hard drives will run fine on a quality 600 watt psu . The total draw is around 475 watts
  4. Yeah, I'm suprised too, getting the amps though is another thing.
Homebuilt Gtx Power Phenom Systems
