Hi,
I'm building a system for gaming (RTS games like Supreme Commander, Company of Heros, C&C) and experiments with virtual PCs. My monitor has a max resolution of 1400x900. I've added a few questions/notes after some of the items. In addition, I'd like some comments of the overall balance of the system. Thanks in advance for your thoughts.
Video Card
EVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130434
Is this enough/too much video card for 1400x900 and max settings for above types of games.
Motherboard
Which of these will work well with the above video card? I can't figure out if either of these supports SLI or crossfire. Does anyone know? Do I need to consider this?
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358
or
GIGABYTE GA-EP45T-UD3P LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128369
CPU
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model BX80569Q9550 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041
Memory
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK (For first mobo)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
or
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10666CL9D-4GBNQ (For second mobo)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231190
Hard Drive
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
CD/DVD
LITE-ON 22X DVD Burner Black SATA Model iHAS122-04
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106287
OS
Microsoft Windows Vista Home Premium SP1 32-bit for System Builders
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116485
Power supply
RAIDMAX QUANTUM RX-700 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready Active PFC SLI Power Supply
http://www.newegg.com/Product/Produ...com/Product/Product.aspx?Item=N82E16811129042
Video Card
Motherboard
or
CPU
Memory
or
Hard Drive
CD/DVD
OS
Power supply
