Tom's Hardware > Forum > CPU & Components > CPUs > Question about temperature please help!
Forum CPU & Components : CPUs - Question about temperature please help!
hey i am using the program speedfan 4.38 and i noticed something very strange. my computer shut of suddenly and i thought it was a power outage but my alarm clock wasn't flashing i have heard that when cores over heat in order to protect the cpu they shut themselves down. so i download the speedfan program.
EDIT: getting diff temps from different programs please refer to this picture:
http://i243.photobucket.com/albums [...] ntemps.jpg
so i am assuming the fact i have a quad core processor and 4 temperature readings means that each temp is a temp for one of the cores. so i have 3 questions;
1. why is only one core blazing hot? or does temp 3 represent the overall temp of the cpu?
2. does that mean i have a faulty processor?
3. will adding another fan fix the issue i currently only have one kinds a dumb move huh?
4. should a buy a after market heat sync? i am currently using the one that came with the cpu
Message edited by shwan on 06-21-2009 at 01:19:04 AM
Sponsored Links
speedfan never worked well for me, but the fact that temperature are reported normally with CPUid leads me to believe the issue is with speedfan, not your CPU. Ive overclocked a friends 9850, they run hot but not that hot. not while the other cores sit at 40*C. The CPUid one looks spot on though.
Reply to mcnuggetofdeath
- 0 +
thanks i was really hoping it wasn't my cpu i think i might add a after market cpu can anyway. feels like i should of had one for a while.
Reply to shwan
1. Speedfan temp 1, 2 and 3 are system component temps, NOT CPU temps. "Core" is the CPU temp. AMD CPU's only have 1 temp sensor for the whole CPU, so you won't see 4 (or 2 or 3) different per-core temps for them.
The CPUid numbered temps are also system components - you'll have to figure out which temp is which component as it varies by MB.
2-4. No problem, so you're OK and don't need to buy anything.
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
- 0 +
so according to speedfan what on my computer is 80C? that number scares me.
Reply to shwan
Keep HW Monitor open while loading up the system and going back to idle and seeing if TMPIN0 and TMPIN2 (temp 1 and temp3 in Speedfan) ever change. If the min and max are always the same it's safe to assume that it's an erroneous reading from a sensor that may not even exist.
Reply to randomizer
All true, but there's still the issue of why your PC shut down.
Reply to Twoboxer
The 80C may correspond to a non-existent sensor, but could be real. If your MB company has a hardware-monitoring program, try it. One component area that can get very hot is the VRMs (voltage regulator modules) -- I know many Abit MBs had this as a weak point. However, VRMs are rated up to 150C IIRC, so 80C wouldn't be too worrisome in that case.
Reply to Mondoman
- 0 +
thanks to all of you for helping tons!
Reply to shwan
There are 404 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
