I'm upgrading my Athlon64 3500+ pc on a tight budget.
New setup,
AMD Phenom II X2 550 BE
Gigabyte MA790GP-UD4H AMD790GX
G.SKILL PC2-6400 4GB 2X2GBCL5-5-5-15 (under 390$ PSU Incl.)
+ DVD-RW, 2 usb devices, 2x120mm 3x80mm and 1 pci tv tuner. "for now onboard Sound and video".
Eventually, Light OC, Gaming and TV.
What's the better choice?
OCZ ModXStream Pro 400W "140mm" (50$) or
Coolermaster Extreme Power Plus 500W "120mm"(50$)?
Thank's!
The Cooler Master will give you an extra 100W for future growth (Although you don't need it for your current specs).
Both are quality units, so so can't go wrong with chosing either.
OCZ fatality one 400w will be on sale at newegg tomorrow for $25 after rebate with free shipping. Or Fry's has the coolermaster 600w for $19.99 after $10 rebate today only for father's day.
Ok and the verdict is? On a couple of forums, the OCZ and the CM have some problems with "noise" when the charge reach 40% and up ... I hesite even more...
Other Suggestions?
hello my bro why r u purchasing AMD or intel is much better than AMD in gaming try to buy this
Core 2 duo 3.0 ghz.
Intel DG34EC Supports upto 8GBz of Ram.
Kingston HyperX memory 2 GB Kingston is better than Corsair.
ATI Radeon ICE-Q HD 4850 or MSI 9800GT
Corsair power supply 450 watts is enough for graphics card.
Any Help (Justcause31@live.com) I am a hard gamer .
ANY HELP... G.K Gaming King.
