Tom's Hardware > Forum > Motherboards & Memory > Memory > Problem with Memory Frequency
Forum Motherboards & Memory : Memory - Problem with Memory Frequency
Hello, i have the following problem with my system. I have a set of 3x1GB OCZ DDR3 PC3-10666 (which supports maximum DRAM Frequency @ 1366 Mhz) installed on my computer, and i've left the DRAM Freq. in the BIOS at Default which is 1066. The problem is that when i check DRAM Freq. with CPU-Z it says 540 MHz, fluctuating +1/-1 MHz and that doesn't go up although i stressed it with Prime95. Any ideas?
Sponsored Links
Nevermind, i figured it out :)
It's seems to be like 540 * 2 = 1080Mhz (looks like i ran more than 1066 for some reason ;) )
Reply to makdak
There are 1190 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
