A $580 (AU) system upgrade, am i buying the right gear?
hi, i've managed to scrounge up $500 australian for a pc upgrade & think i've managed to build something that would work ok.. your thourghts would be greatly appreciated!! thanks. I use my computer for graphic art, & also for gaming, so need performance for both...
:) mark
old system:
Asus a8n-sli motherboard
2 x 512 DDR 333mhz dimms
AMD64 Athlon64 3000+ (1.8ghz O/c to 2.39ghz)
nvidia 6600gt x 2 SLI gpu's
(& 2 sata drives, dvd drive, etc..)
new system:
ASUS P5KPL/1600 Intel G31/ICH7Chipset - $95
INTEL CORE 2 DUO E7400 2.8GHz LGA775 CPU (3MB CACHE, 1066FSB) - $215
512MB ATI SAPPHIRE HD 4850 DDR3 CrossfireX PCI-EXPRESS 2.0 GRAPHICS CARD (2xDVI, TV-Out, Support HDMI, with FAN) - "Best Value VGA" $229
2GB DDRII-800MHz PC-6400 ADATA DESKTOP RAM $45
comes to $584 Australian, (which is $403 USD or $294 Euro).. is this upgrade worth it, is there anything i should change.. some questions
1) this mobo supports 4 gig ram max, but has four slots.. better to run 2 x 2 gig sticks or 4 x 1 gig sticks??
2) would i be better spending more on a faster cpu or a gpu??.. considering i plan to use the computer for both graphic design & gaming..
3) what is better SLI or xfire??.. i figured getting this board would mean i can upgrade with a 2nd card in the future using Xfire, but if SLI is better I can spend a bit more money buying a better SLI board, & use my old 6600gt x 2 cards for a bit until i can afford a newer card..
thanks guys!
4 answers Last reply
More about system upgrade buying gear
  1. 1) this mobo supports 4 gig ram max, but has four slots.. better to run 2 x 2 gig sticks or 4 x 1 gig sticks??
    2x2gig because you can always upgrade. the MB might get a bios update to support more mem.
    more games are GPU dependent so put more money to the graphics. CPUs are easy to overclock today.
    depends which games you play. and secondly if you want a dual GPU system i would advise getting a MB designed for it. this board has only got one x16 PCIx slot.
    also this asus board got alot of bad press on new egg i think.
  2. this is the board here, which i tells me it is xfire ready..
    http://www.asus.com/Product.aspx?P_ID=cdTU6DnRnZWCYVhR
    I think the P5KPL-CM board has only the 1 PCIe slot.
  3. Yes, the board supports crossfire...
  4. It looks decent, I would get a CPU cooler too though so that you can OC the CPU some to get the most for your money. Xigmatek S963 is a pretty decent little cooler and pretty cheap.
New Build Systems
