New system build/upgrade
First off - great service here, guys are really helpful and knowledgeable!
My primary PC use is trading equity futures (sadly my gaming days are long past),
and I'm looking at a midrange to high end update. Personally, I've never felt it wise to buy the absolute latest - I was more of a midrange upgrader based on value.
General wants/needs as I see:
64 bit OS (the extra memory to a number of apps) XP or Vista? FYI, alot of my apps are java based
motherboard/CPU combo (Intel vs AMD etc)?
monitors and video - currently have dual but i'd like quad. Monitor advice not necessary (have good 22") but i question whether a quad card provides value (premium priced) or fine to go with 2 cards via SLI or crossfire? and which ones?
Case is quality construction but only 450W, do i need more W??
hard drive im good
I realize that optimization is important so I'm really at a loss regarding certain combinations.
Any suggestions are greatly appreciated.
Jimmy
20 answers Last reply
More about system build upgrade
  1. Give your budget range...
    Just taking Mid-Range as less than $1000 and
    High Range as above $1000 and less than $1500 or mayb even upto $2000
    For a start,
    Midrange -
    CPU - Phenom II 940
    GPU - 4830 2 cards
    (Not in crossfire beacuse to get a quad montior setup, u shuld not crossfire...I mayb wrong though)...
    High Range
    CPU - core i7
    GPU - same as above...
    Chose 4830 because we just need a card tat supprt 2 monitors...and actually u can get even to a less powerful card like the 4670...
    Give us the budget and we can suggest the best value component for tat range...
  2. If you aren't doing much gaming, you can certainly build pretty cheap.
    I'm not sure exactly what you need, but I just build a computer for my Grandma for $250:
    E5200
    G31 motheboard
    4GB Corsair RAM (DDR2 800)
    500 GB HDD
    Corsair PSU
    It's a nice machine for basic tasks.
    If you have money to spend, you can get a very nice machine for $800 or less. If you have more than that, check out i7 or Phenom II.
    With a more concrete budget and purpose, it'll be easy to refine the scope and pick you out some parts
  3. If your "gaming days are long past" you can just use onboard video and be fine for most things, unless you do video encoding or photoshop, which do benefit from a good GPU. Again as the others have said, without knowing exactly what your budget range is then its difficult to make a suggestion, but if you want a medium to higher end rig, then go for this:
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.165047
    And if you still want the option for moderate gaming, get a discrete GPU like this one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102822
    If the PSU came bundled with your case and it isn't like an antec or other reputable brand, then I would buy a different PSU as well, like this one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008
  4. Thx gkay09. My preference is to spend as little as necessary but i'm willing to part with $1000 or less.
  5. Thx huron, wasn't sure how much detail to provide. I can spend $1000 or less and my main use is for trading futures, so I run a my trading application (basically a grid with live data), excel with custom calculations based onlive data, 2 charting software, on top of standard apps like outlook, IM, and web browsing.
    E5200
    G31 motheboard
    500 GB HDD
    Corsair PSU
  6. Thx for the links xthekidx.
    Not totally ruling out gaming but wanted to mention my primary purpose - thought it might be relevant whether it is 2D or 3D
    As I mentioned to others, $1000 is about the max i'm willing to lay out.
    Wanted to add: I'd like to moderately improve cooling beyond the basics. Any suggestions on what to consider or definitely avoid?
  7. Well ok here is what I would do if I were you:
    https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=8899425
    You can buy the CPU and motherboard in a combo deal and save a bundle:
    Then you get $30 MIR. That should bring the total to about $1000 after shipping, if its still too much, then you can either get a cheaper PSU (the one included there is assuming you will add a second GPU later for crossfire, if gaming is not a huge concern then a downgrade to a 550w would be fine) to something like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008&Tpk=ls-550
    or you can downgrade the case to something like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&Tpk=antec%20300
    either one of those changes should put it within reach for you.
  8. Here is config, I feel will be good for you...
    There will be many parts what other have suggested too, implies they are the most preferred...
    1. AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX - Retail
    2.GIGABYTE GA-MA790GP-UD4H AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - Retail
    1. AMD HDZ940XCGIBOX: $225.00
    2. GIGABYTE GA-MA790GP-UD4H: $138.99
    Combo Discount: -$50.00
    Combo Price: $313.99
    RAM - G Skill 2X2GB...$39.99
    Free Shipping*
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
    CASE + PSU combo --Well actually the PSU is a overkill but the combo is a worthy buy...
    The case has so many additional fans slots...will provide adequate air flow...
    1. Corsair Memory, Inc. CMPSU-850TX: $129.99
    2. Cooler Master RC-690-KKN1-GP: $79.99
    Combo Discount: -$30.00
    Combo Price: $179.98
    $20.00 Mail-In Rebate
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.176939
    CPU heatsink + HDD combo(Ya I know its weird)
    Both the best components...
    1. XIGMATEK HDT-S1283: $36.99
    2. Western Digital WD1001FALS: $119.99
    Combo Discount: -$5.00
    Combo Price: $151.98
    $10.00 Mail-In Rebate
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.177110
    First I had given the 4830 as the option, but the best option will be to go wit the 4850X2 $279.99
    Free Shipping*
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102809
    Reasons why I chose 4850X2 :
    1. Within the budget.
    2. I read in a forum about a guy running 4 monitors with this easy when he is not gaming(Disabling the crossfire in CCC) and when he feels like playing, he enables it...So no hassle of using 2 seperate cards...
    So the total comes to $966 without rebates...
    Well within $1k...
    So with the extra money buy addtional case fans...
    Free Shipping*
    Free Shipping*
    Well within $1k...
    That is a great build but if he needs an OS to fit in that budget you will need to cut back a little bit...
    :D Thanks...
    But adding an OS to the build will add about $60 more to the budget...which am sure he can adjust with ;) ...
  11. And regarding the OS get the vista home premium 64bit for now and when the Win 7 comes out, upgrade the OS
  12. Thank you very much! Last question before i order - any benefit to go to a faster RAM or is the suggested optimal for the config?
  13. If you can find 1066mhz ram for the same price then you can go for it, but make sure it has decent timings. You won't see much benefit from getting faster ram so its usually not really worth it.
  14. ^+1 if you want to, you can go for the 1066...
    How about this??? Kingston HyperX...1066 at 2.0V...not bad...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820104097
  15. gkay09 and xthekidx - extremely helpful advice, thank you.
    Small issue - NewEgg is forcing me to order from newegg.ca.... I've been able to find almost everything but motherboard.
    M/B - either of these?
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128387
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131368
    Video card - is there a pro or con other than price to getting say one 4850x2 or 2 4850 cards?
  16. If you want to have onboard graphics as a backup, then get the ASUS...else stick with the Gigabyte...
  17. As for the 4850X2, read my post above where I had given the reasons for going with...
    "I read in a forum about a guy running 4 monitors with this easy when he is not gaming(Disabling the crossfire in CCC) and when he feels like playing, he enables it...So no hassle of using 2 separate cards... "
    But if you want to go for 2 separate cards, then its fine...But go for the 1GB version as it can handle higher resolutions very well and would compliment the quad monitor setup very well...
    But I would suggest you go for the 4850 X2 2GB because it is cheaper than 2 4850 1GB...
  18. I forgot to post a conclusion:
    I went with the AMD Phenom II X4 940 black, Giga GA-MA790GP-UD4H, G Skill 4X2GB, ATI 4850 X2 2GB, Cooler Master RC-690, Corsair CMPSU-850TX
    Case is exceptional value, added 4 more fans (8 total) and it is quieter than my old system LOL
    One problem:
    XIGMATEK HDT-S1283 obstructed 2 RAM slots with this motherboard, so i sent it back and i am currently using the stock cooler - so no overclocking at the moment
    VERY happy overall and thanks to gkay09 and xthekidx for their expert advice.
    And Newegg customer service is outstanding - first time i've dealt with them and i will return.
    thx again
  19. Try the sunbeam core contact freezer CPU cooler, but read the reviews first to make sure it works with your MB.
New Build Systems Product
